Originally Posted By: chrisri
Originally Posted By: JOD
I'm using Mobil1 5W30ESP in mine (same car). It seems that this may be the best chance of fighting off intake valve deposits, and looking at a complete VOA (including NOACK) this looks to be a very high-quality oil.
Given the low starting TBN of it (and other low ash oils), I wouldn't extend the OCI over 8km, particularly if you're short-tripping it.
This is what I recommend her, and this is what Mobil UK recommends for this particular engine. Other option I gave her was Shell H. Ultra ETC which carries similar approvals.
Eddy, this is naturally aspirated FSI engine which is direct injected if I'm not mistaken. Do you stand by your previous recommendation since you've assumed that it's a turbo engine?
Yes, I would still use 5W40 VW 505.01.
Mid-SAPS wll help with deposits. Also, Europe has different burn so not as much worry as in the U.S> when it comes to carbon deposits.
However, it is still fuel dilution monster. So, oil will get diluted.
