Cleaner to remove trailer wheel bearing grease?
va
After posting a thread on which grease to pack my harbor freight wheel bearings with, I have decided to use Redline CV-2 grease.
The question has now become what to remove the oil grease with. Apparently the grease is some inferior low speed Chinese grease and must be removed. Even the instructions warn that the bearings must be removed and repacked.
Here is a writeup on the repacking process:
http://www.yourepair.com/1913/how-to-remove-inner-bearing-and-seal-on-harbor-freight-trailers.html
Some posters have claimed that you must go through several cans of brake clean and this doesn't sound fun at all.
I have read that gasoline is a no no as well.
Would mineral spirits be a good idea?
Thanks for any thoughts!
i;m far from an expert, but did this in auto class. To do the clean, I used the parts washer.
So if I were you, i'd just pick up a jug of parts washer fluid, which is degreaser, rather then brake clean which may evaporate too fast
Originally Posted By: Donald
Originally Posted By: Chris142
If you pack them correctly you will push the old grease out with the new
+1
+2
