Basically Im wondering what people think about doing the above, going from RCA cables from my head unit to an ADC and then straight into a DAC to go back to RCA cables to my amp.
What Im trying to do is lift a ground loop that I cannot seem to fix. Ive tried everything I could think of and have found on the internet to fix it and haven't fixed it. My fix right now is just to run it really loud and it disappears but If I have people in the car obviously then you cant converse with them or each other so I actually usually just shut the system off in that case as its embarrasing for me to run around with the alternator coming through my speakers. The injectors like to show up to at idle rpms as well in there too.
So far Ive (in no particular order since I dont remember, only that its been done)
Moved the ground for the amp closer
Sanded the amp ground location on the body for better contact
Pulled the amp off the steel wall its screwed to and set it on the carpet to isolate the metal body from the car body.
Moved the radio ground from the harness to a dedicated ground on the transmission tunnel, that I also sanded.
Unplugged the amp from the head unit to confirm it was only occurring through the audio connection. Amp on and no signal is dead silent.
I also unplugged at the HU end to ensure it wasn't being induced through the cabling.
This is the second HU this amp has been behind so I doubt its that. I went from a Clarion CD player to a double din Kenwood touch screen.
Basically I think it s ridiculous we are still fiddling with an unbalanced analog connection in cars in 2015. I read all kinds of bad about those cheap ground loop fixers destroying the audio and I don't want to do that, make the whole thing a waste of time. So I was actually hoping I could find almost like and optocoupler (which is where the idea came from) where the ADC and DAC are right in the same unit you have RCA in and RCA out but I haven't found anything like that, but I still have been looking at the idea even if I have to run a short cable between the units.
