New patent by Airbus:
http://www.businessinsider.com/airbus-ju...n-1-hour-2015-7
Wonder what the ticket price would be.
Quote:
The jet is powered by three different types of engines that work in sequential order to get the craft aloft, into cruising altitude, and then up to its cruising speed of more than 3,000 mph.
To get off the ground, the craft will use two turbojets mounted under the fuselage as well as a rocket motor mounted in the rear. As the Airbus lifts off the runway, it will climb vertically like the Space Shuttle. Right before the jet reaches the speed of sound, the turbojets shut down and retract into the belly of plane — leaving only the rocket motor to guide it up to an altitude of more than 100,000 feet.
At cruising altitude, the rocket motor will shut down and retract into the fuselage. Then the plane's pair of wing-mounted ramjets take over and propel the aircraft to a top speed of Mach 4.5.
