Originally Posted By: BurrWinder
Originally Posted By: Bgallagher
Originally Posted By: ExMachina
What is it with some GM engines and timing chains? I guess they had trouble metallurgically processing the surface hardness, a quality control issue for a while, likely that.
As for engines in Equinox/Terrains:
Looks the 4-cylinder changed, but
really it did not. The LEA is an E85 (mo' alcohol capable version) variant of the LAF, that's all, not much going on there, just flex fuel.
That 2.4L four cylinder has some stellar highway EPA fuel economy ratings at 32 MPG, fantastic for a biggish boxy SUV (2wd form is best here). If you get the rocket ship 3.6L 300 hp V6 option, your highway MPG drops to 24 MPG (down from the 4's 32 MPG), which is weird because other GM cars in the same weight class respond better to a 4 cylinder and 6 cylinder comparison:
https://en.wikipedia.org/wiki/GMC_Terrain and fueleconomy.gov
Interesting, I would hope in 5 years that they would have corrected that issue? If not I would assume that would be covered under the 100k/10 year powertrain warranty as it is a known issue. So far we love the car. The 2.4 has enough power for us and the gas mileage has been pretty good so far. Thanks guys!
The INTERNALS did change... to the better, upgraded parts - away from the ones that were having issues in the 2010/11's... Did NOT mean an engine variant change....
BurrWinder
phew haha. Thanks for the information!
Originally Posted By: Ethan1
Since you live in Massachusetts, you're susceptible to the issue where the PCV system fills with water and freezes up overnight, blowing seals and causing all your oil to leak out. Sometimes it happens in the driveway, sometimes about a block from home, always on a cooold morning.
This is a new one to me. How would you prevent that?
