Does anyone know if the inside of the filter housing can go bad? I think it is the by pass valve in there. A buddy of mine said Toyota has replaced his twice. He has 90k on his Camry. Other than making sure that the spring still had tension on it how should you know if it was bad? Oil analys?
Patrick
Patrick
