Can anti-seize be used instead of grease in a lower friction, high heat application? In this case I'm trying to keep a couple of meshing gears lubricated. They aren't running at high rpm or continuously but are subjected to temps in the 500 degree range (I'm guessing). When the gears do run the grease has a tendency to fling off.
