Originally Posted By: philipp10
stop over-tightening them in the first place.
It's not me! (usually) It's doing friends oil changes and such - the knuckleheads at the quickie-lube must stick them on with an air wrench or something. >_
Originally Posted By: ecotourist
The natural question is why are you having so many stuck filters?
In recent years I've used a torque wrench to tighten filters.
It's not (normally) lacking leverage on the wrench itself (except with those miserable strap-type filter wrenches, the short plastic handle is not enough then) but not being able to make the filter wrench hold properly onto the oil filter body. Short of like I said, hammering on a deep aluminum type one - which I then cant get off the dang filter without about a half hour of public profanity and bashing it against the concrete. :- P
When I put them on my normal routine was always to first smear oil on the filter gasket itself, and then go hand tight, and then tighten 1/2 turn past this. The [censored] plastic filter end cap wrenches wont even hold onto my filters this long - the deep aluminum one tightens it just fine, but then it's stuck to the filter and i've the darndest time getting it off the properly tightened filter since banging at it doesn't always work.
Despite never going more than 1/2 turn past hand tight (maybe I have really strong hands??) and oiling the seal I not infrequently have a struggle getting them back off. The aluminum deep filter end cap thing never slides on very nicely and will slip if not all the way on. Then if all the way on never comes back off again. I've started just doing hand tight (no extra half turns) but one is still stuck now. (temp differences?)
Can we keep most of the suggestions to tools? I've seen the three-prong type ones but wondered if they were best or as good vs the Lisle. Which brick'n'mortar places sell the Lisle anyways? It doesn't look familiar.
