Originally Posted By: madRiver
That is something the Subaru AWD and other top tier AWD prevail at. Many top tier AWD are very expensive and Subaru is exception to that rule in base models across line.
However as you found majority of time not needed unless you live in tough conditions.
So how would a Subaru fix that predicament. Basically the worst combination for any AWD system. Loss of traction from opposite sides of the vehicle. Outside of a locking differential (which IIRC Subaru doesn't offer) you;d be screwed either way as the center diff would be sending power both directions and the open or LSD's would be trying to get that other side to bite.
The Ford system is quite good - it uses brakes to help out but in this extreme situation it couldn't get me going.
