Originally Posted By: MolaKule
Originally Posted By: Or
Your post is kinda vague and I'm not sure if it's a question or what, or what your truck may really call for (what year?), but:
Some transfer cases want ATF to assure a specific clutch lock-up. If you substitute a different ATF or lube with a different weight, you might get a "better" shift/lock up based on your butt in the seat. That is because it is slipping the clutch plates together and it feels smoother. And while it is making your seat feel good, it is shearing the friction material off of the clutch plates as it slips them together slowly. Better feel, much shorter life.
I really would think this through hard before second guessing what the well-educated, thoughtful and dedicated engineers decided was the best for your particular system when they designed it and dictated the specs.
Again, I can't tell enough from your OP to get specific, but I encourage you to think it through to make sure your choice is indeed wise.
That paper I posted was for MT specific lubricants and are NOT to be used in Transfer Cases or ATs.
Out of curiosity why not? Assuming the viscosity is about the same and the transfer case does not have clutches, why not use a MTF if one has it handy? I realize the gains might be minimal.
Just curious.
Just curious.
