Originally Posted By: RichR
Originally Posted By: rshaw125
Ridgeline is a Honda Odyssey.
Ridgeline was built off the first generation Acura MDX.
Yes, the Ridgeline appears to share a ton in common with our 2005 MDX. The Pilot and MDX are loosely based in concept on the Odyssey, but they incorporated an integral boxed frame for chassis rigidity (which the Odyssey does not have). You can't separate the body from the frame after assembly, but there is the concept of a "rolling chassis" here:
There's not really a lot shared with the Odyssey, though that is a popular misconception. The Ridgeline's chassis really does seem to be a "hybrid" of a boxed ladder frame and a unibody...like a Pilot or an MDX, you can't "unbolt" the body from the frame, but structural "frame" pieces created separate from the unibody (and joined during assembly) do exist.
The Ridgeline also shares a unique rear suspension setup. The MDX, Pilot, and Odyssey at the time all shared a similar rear spring/damper package: a coil spring with bump stop in the center sat on one of the rear lateral arms, and a separate shock absorber attached to the knuckle. The Ridgeline uses a unique coil-over-shock design that apparently increases payload and better controls suspension movement.
I got the Ridgeline on Saturday, and have been doing a lot of cleaning over the weekend. My brother or his father-in-law, the original owner are not quite as careful with their vehicles as I am, so there are some things I need to polish out. There's a small dent on the driver's side that I will try to pull out. Some areas need some touch up paint. I'd consider it a typical used vehicle that perhaps has a bit more refreshening than average before it could be put on a retail lot for sale.
That stuff is fun to me, though. I don't intend to continue this in this thread...when I'm ready to post some pictures and initial thoughts, I'll start a new thread.
