I was thinking of adding an oil pan heater before this coming winter. My truck is kept outside and last winter here in Western MA it got real cold although I am sure not as cold as some of you out there. There are a few manufactures that make a model that just sticks to your oil pan with some sort of industrial adhesive and heats the oil. They are not that expensive around $100.00. Other then quicker starts do you think this would result in less engine wear since the oil would be already warm on start up? Do you think its worth it?
