I had this on my wife's little 2 for 5k. I changed it out early after I first learned of puros tearing problems. I replaced with one of those mysterious fu filters at the time. That was before I discovered the shady language fram uses concerning their efficiency abilities. I ran that for 15 k
This classic sat outside under an RV I have on the ground for a year and a half. Was all mucked up so I cleaned it up first. So this is after a 5k fcoi and 1 1/2 year out in the elements.
Code is f06e28e1 so if I interpret correctly, it was born in 6 of 2013.
This little l14612 is a Purolator and not a tearalator. It looked great and had no tears. Adbv was plenty pliable.
If I didn't have a stash of filters now, id go back to this filter and keep cutting open. Price is right and this model might not be a problem one.
Metal shavings r from hack sawing
