Originally Posted By: Avery4
Yes, it overheated and melted the oil cap. It still runs great and passed the head gasket test though!
Wow, amazing!
The intervals you suggested are both grossly under utilizing both oils. If "cheapest" is your goal, a full syn run longer is usually less if it is run the proper extended interval it is capable of. Most don't do that though, even here.
The affordable Super run to 4-5k intervals would be just fine IMO.
