Hi Guys,
So of course before 400 miles trip ... AC failed on my Cayenne....
Checked fuses
Hooked up gauges ...
- all fine
But then I looked at the AC pulley ... and could tell that something is wrong ..looks like it kinda separated .. the middle part is no longer spinning only the pulley ...
Found replacement compressor ... looks like OEM is made by Denso
Do I need to replace anything else .. ? Do I need to add in line filter do flush ?
Or can I evacuate system, replace compressor add oil do vacuum and re fill the system.
I read online ... that I should replace everything in AC system
thx
Checked fuses
- all fine
thx
