Originally Posted By: ZeeOSix
And I have no real idea what "choosing a filter that's most efficient at 98% means??? Help us understand.
I would see a statement such as "choosing the filter that's most efficient at 20 microns" to make a lot more sense in this context personally, but it still isn't quite what I would do.
I would choose the filter with the most area under the curve between 10 and 20 microns, absent any data showing the magnitude of damage caused by particle sizes near those bounds. That's called
Integration and would be based on something quantified by empirical studies of what causes the most wear that the oil filter can address.[/quote
First off, I wouldn't extrapolate anything. You either have the full curve or a point or two or three of data to make any decision on efficiency. I would not extrapolate anything - I only use what data I have. The chances of getting full "Efficiency vs Particle Size" curves for everyday vehicle filters is probably below nill. You might find this kind of data on very high end commercial filters from manufacturers like Donaldson, etc.
So based on that, as I have said before, the best filters shown on the graph are
the ones that have the best efficiency at 98%, which is the data point they are all compared at. And as can be seen in this example, the
filters that are best at 98% are also best at every other particle size. That's how filters behave, and that's why you can chose the best filter by knowing one or two data points.
Originally Posted By: Nyogtha
Here's an even simpler example. Fram Ultra is stated to be 80% efficient at 5 microns and 99+% efficient at 20 microns (but I'll just use 99% as the "+" isn't quantified). I'll pick the XG 2 model for my truck. Then compare that with the Napa Gold published beta ratios for the 7899 (even though we don't know the test method used). So 50% at 6 microns and 95% at 20 microns. I can picture in my head without needing to plot a curve on paper or with electrons that the area under the curve for the XG2 will be greater than the area under the curve for the 7899 - and that's also because I have two data points to interpolate between rather than attempting to extrapolate from a single data point. The curves are similar shape because I only have 2 data points on each curve. But the slopes are different (change in rise divided by change in run). The XG2 slope is 1.27. The 7899 slope is 3.21. To you, the same; to me, quantitatively shown, quite different.
These two lines most surely will cross at a point if extrapolated - parallel lines by definition must have the same slope / direction, never crossing. But I'm also comparing 2 considerably different types of media rated with non-similar efficiency at 20 microns. Filters with similar media may well cross in this range of particle sizes.
You're making this way more than complicated (ie,rocket science) than it needs to be.
Of course if a Filter A (Ultra)
is better at 20 microns than Filter B (NAPA Gold), then it will also be better at 5 or 6 microns. That's all I have to know to chose the better efficiency filter over-all. And doing so will most likely also give you the filter with the best "area under the curve".
I'm willing to be convinced though if you can supply the graphs of ISO 4548-12 data from numerous off the shelf oil filters with similar media in this particle size range to show they won't cross.
LOL ... OK, how about you send me $5,000 for each filter to be tested per ISO 4548-12 and I'll put all the data together.
Seriously, that's how much an independent laboratory will charge to test filters per ISO 4548-12. Or maybe the board can raise $225,000 to buy our own ISO 4548-12 test bench system. Or you can spend some time on the internet Googling to see if you can find some ISO test results. I think there are some out there, as I do recall seeing a data sheet or two that was actually from the ISO 4548-12 test.
Can you please explain what I've highlighted in red? This is the third instance you've posted this. 98% isn't a particle size, so with only one data point, or maybe two, published by just about any filter company, many of which are at a point other than 98%, this doesn't make any sense to me.
So based on the ZeeOSix rule that no filter efficiency lines will cross, you're telling us in 2007, using ISO data from the chart I posted early on in this thread when Wix & Napa Gold efficiencies were being discussed, you're telling us absolutely the Fram PH8A was definitely the most efficient filter at 10 microns, regardless of the fact the Mobil 1 filter uses blended media with enough structural integrity to go up to 15K miles on synthetic oil.
Why not use the ISO 4548-12 test results for Wix and Wix made-fors on the second page of this document?
http://www.mobil.com/Shared-Files-LCW/mobil-1-ep-oil-filter-design_amer_en.pdf
I just don't buy it - because I know only a Sith deals in absolutes. I can ask someone if other data points from that chart can be shared but I predict a low probability of that occurring.
In fact, I think I added more ISO 4548-12 data in this thread than anyone ...Bueller ...ZeeOSix ... anyone?
Also, the ZeeOSix Rule means an intact PureOne must have a better efficiency than a Fram Ultra at 10 microns, because the "+" in 99+% isn't really quantified, regardless of the differences in media used. Again, I don't buy that.
