Hi, I have a Wood-Mizer sawmill with a 42hp Kubota turbo diesel (V1505-T) and end up starting and stopping the engine at least once per hour while sawing. Would an application like this benefit from a pre and/or post-oiler.
The mill will be used upwards of 2000 hours per year, which yields at least 1000 hours on the engine. Given that the mill itself will still be useful in a decade (it's a '98, but only 2700 hours), I want to make the engine last as long as possible. I also recognize that the reduced engine wear would yield a small but significant savings in fuel.
I currently run Amsoil HDD 5w-30 oil as well as their bypass filter (dual mount, EAO26 and EABP110), although I just added it so I don't have any oil analysis to back up this decision (saved a sample of the conventional oil to send in as well).
In addition to making this engine last a long time, I'm also considering any of these modifications for a 55hp Cat powered sawmill that I will be purchasing soon and quite possibly using for the next 30 years, which is part of my incentive to test this all on a less-expensive motor. I'd already installed a bypass filter on a 28hp Kohler gas sawmill without issue, but also too soon for analysis (250 hours on oil).
Thank you for your advice and input,
Jay Clarke
Jay Clarke
