Originally Posted By: Vikas
Originally Posted By: Shannow
Nope, the lowest friction point is at a higher wear level than the lowest wear level.
It occurs just as hydrodynamic lubrication is ceasing, and when the boundary lubrication, and additives kick in.
Problem with statements that "feel" right is that they are often wrong.
Can you explain this better? I mean if you are going to claim "water is not wet", you do have to give little bit more rigorous explanation than brushing it off saying "feel" is often wrong.
I'll have a go:
You might THINK that when an oil film breaks down to the point where metal is on metal, Friction or Drag whould be higher.
Apparently, that's not the case. It actually takes more power, meaning there is more friction or drag when the engine parts are NOT in contact, but are riding on the oil film.
However the trade off for that (little) extra friction is a (little) wear on the moving parts.
So, how much are we talking about?
Probably, ideally, not much.
The extra friction, or drag, of maintaining a boundry layer MAY amount to .5% drop in fuel consumption.
Verses extra wear on an engine that runs (at times ) metal to metal, which might be more difficult to quantify.
Climate and useage will also play a big part.
