Hi Guys,
I'm replacing radiator on my parents car ... EX35 with VQ35HR engine.
As for bleeding ... I have Air Lift 2 ...
But this system is weird .. there is a Reservoir + a radiator CAP mounted on the block itself not on radiator ....
Do I place Air Lift in the Block ( Radiator Cap ) and pull vacuum there ?
Usually I will pull Vacuum from reservoir .. but this system is not pressurized ?
Should I clamp the hose to reservoir so vacuum can build up.
Thx
Thx
