Originally Posted By: John_Conrad
greetings:
i did some searching last night and was unable to find an msds for this product. it does not mean it does not exist, i just could not find it on the www. in this day and age of safety, it rings a bell for me. how can doctors or emergency rooms treat people who may ingest said formula with out knowing what is in it and how to proceed.
that having been said i still keep an open mind, until i can find out what is in it, but it is likely like most other addy's just some base oils with a minute something or other "proprietary" thingy that is so minute that is has no effect.
as far as the temperature drop, this happens every winter on my vehicles here in the midwest. the colder the temperature the harder it is for vehicle to get up to operating temperature. too many variables come into play here.
i also encountered several threads on the www where there was the possibility of the chlorine that was mentioned my molakule.
in the end if it makes you feel good about using it, then so be it.
no offense or ill will meant.
good day.
I have pulled in the mountains several times in the winter, a diesel will lose water temp so I am used to seeing that drop. The driving condition when I experienced the water temp drop is on a 10 mile plus down hill where the engine is in lower gear spinning at 3 to 5000 rpm slowing truck and trailer. This is after a climb to the pass where trans temp climbs to over 200 degrees. Look I do not know how the stuff works but the claim in their literature seems to be correct from what I have experienced. I just want to make sure I am in the right forum on oil additives not a general forum trying to sell an elixir and linking to a website where you can purchase said miracle product directly from me. Just checking.
I have pulled a the head off a 2-stoke snowmobile engine to see if there were any signs of the product. The combustion chamber has a shinny gold brown sheen that covered the entire area. There was a few, maybe 2 spots in each cylinder about the size of a dime with the same golden sheen. ER states that it bonds to areas where heat is present. Well running it through a 2-stoke there is going to be plenty of heat in combustion chamber. The pistons did not have the sheen but where really hard to read any wash or carbon build up to determine if air fuel mixture is correct.
