Originally Posted By: HosteenJorje
That's diametral clearance, right? The clearance you would see using Plastigauge. Seems too much to be radial clearance.
Good point, I was talking diameter.
If the OP could confirm how the measurement was take and if it's radius or diameter, that would stop any confusion.
If it is radius. even more reason to say: Run a Thicker Oil !!
Or rebuild the engine.
