Originally Posted By: Pop_Rivit
Originally Posted By: jhellwig
Please, explain your "additive separation based on quantity" theory. I'd really like to know more.
Yeah mee too, should be good entertainment...
You mean to tell me that a place where people are so nit picky that they smell their oil and filters this is a crack pot theory? People here agonize over how their filters and oil are stored and add all sorts of stuff to their vehicles to make it last just a tiny bit longer.
We all know that addatives settle out in a bottle of oil. It is evident by the dark stuff at the bottom of the bottle. For the sake of argument lets just say you had a geo metro with a 55 gallon sump. It would take so long to circulate almost all of the oil in the sump that addatives and contaminates would settle out in the corners away from the pickup. Compair that to the normal sump size and think how often the oil will be turned over compaired to the 55 gallon one. The more oil the less it circulates. It doesn't how much you have but the more oil in the sump the more will separate. It probably won't be enough to make a noticible difference in the longevity of the vehicle but it is still going to happen.
Hogwash. If you really knew what you were talking about you'd know how to spell "additives", "compare" and "noticeable". I've never seen additives (note the correct spelling) settle out of a bottle of oil. I will admit that I don't maintain an oil "stash" and only purchase what I need when I need it. But given that most vehicles are operated on a regular basis your "crackpot theory" (note that "crackpot" is all one word) doesn't hold. Additives don't settle out unless the oil sits for a very long time. Even if your Geo Metro is run once a month you won't see any additive separation-additives simply don't fall out of suspension that quickly.
Ah yes, perfectly valid argument. Clearly I have no idea since I can't not spell good.
Yes additives do settle out.
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3549894/Additives_settle_out?
Contrary to what you are saying the don't just suddenly fall out after a specific amount of time. They are always falling out when the oil is not circulated enough no matter what. It is going to happen whether you like it or not.
And finally I said it probably wouldn't be enough to matter. But it will still happen.
