Honda has to do a lot of Things things like emmisdions, like oxides of nitrogen (NOx) things that are effected by high temps....
Honda has to ensure the cooling system works in Nome Alaska, and death valley at the same time. If you don't see high heat why sacrifice fuel Eco for cooling reserve you possibly don't need at all.
There are Hondas that respond well to high temp stats, and a lot of Hondas respond well to warm air intakes.
If Honda was interested in pure fuel economy my insight would get 100+ mpg and almost always run in lean burn, and not have to richen to clear the catalysts every once and a while
