Originally Posted By: Brad_C
Originally Posted By: riggaz
You can pedal bleed by opening the nipple, pumping brake pedal to the floor and holding, tightening the nipple then releasing the pedal (and repeating over and over) but some times on high mileage cars you can get master cylinder trouble after this.
In fact it's almost guaranteed. The fluid in the reservoir absorbs moisture, this sits in the back of the master cylinder bore that never normally gets touched because you normally only get about 50mm of pedal travel. This un-touched bit of bore gets some slight corrosion from the old, wet fluid. It also accumulates any grunge or dirt from decaying parts, and the first time you floor the pedal the piston sweeps past all this grit and tears the seal to pieces.
If you want to pedal bleed, work out how far you push the pedal in your worst case emergency stops and put a wooden block behind it to stop you pressing it any further, then pedal bleed. You can test for damage by pumping the vacuum out of the booster with the engine off and standing on the pedal. If you've got a damaged seal, it will slowly (where slowly might mean 10 seconds or it might mean a minute) drop to the floor.
This is a common injury on any car more than a couple of years old, and any car that has not had regular fluid flushes. It's easily prevented however.
Pumping the pedal to the floor is exactly how I did my brakes.
Is there any way to reverse the damage doing another system flush? Help!
