I own the 2014 Accord Hybrid. Base model. I like the car. Gas mileage is terrific. In my rural driving, Spring, Summer, and Fall, I get over 50 mpg. Sometimes way over. Worst mileage since new was coming back from FL to WV, on Interstate, in December, running about 75. Got 40.5. All mpg were calculated, not from in car display. Mileage drops in very cold weather. This is not a car for the frigid north. But in more normal climes, it works fine. Got a little over 14k on the odo. No problems at all. I changed the oil at 7500, with at least 40% life left. I will change again at 15K, but according to the OLM, should go 10K -12K. Using Fram Ultra and Valvoline syn. Next change will go to Pennzoil Plat. I changed the cabin filter, but the dealer says they will go 3 years. Cheap enough Denso from RockAuto. Car handles well, suspension is tight, but does transmit pavement bumps. I traded a 2011 Hyundai Sonata Limited. The Honda felt like a sports car compared to the Hyundai, and I had installed a strut bar and better tires. No belts on the gas engine, timing chain, not GDI. Ought to be a long lived engine. When you need to pass, there is plenty of power. Tranny directly couples the gas engine to drivetrain around 47 mph. You feel the "shift", but it is no more noticeable than any trans. Gas engine starts and stops when load calls for it, or battery level drops. Car runs as a true hybrid at lower speeds with gas engine driving generator only. I don't drive as much as I used to, and have to force myself to run the gas tank down, just so I can get "fresh" fuel. Can get as much as 800 miles per tank. You can see impact on mileage from driving with lights and heat on, as they are electric. If I had another inch of leg room, it would be even better. Back seat much easier to access than Hyundai and more comfortable. Trunk is a bit tight. With current gas prices, you will have to keep it a long time to recoup the premium price over the regular Accord.
Honda is dropping the plug in Accord. Expensive.
