I have a 2000 Ford Ranger with the above motor; it has always been a noisy motor, making sounds somewhat like loud tappets, but only when you tromp the gas. A buddy long ago dubbed it "Old Growly". For the first couple years I drove it with Amsoil but then switched to a car and seldom drove the truck; maybe 1500 or so a year. At that point I went to conventional oil in the proper grade and changed once a year. Last year, I resumed driving the truck regularly and for a couple oil changes used Mobil 5000 conventional. The growling continued as it always had; I took this to be normal for these motors.
The last oil change a couple thousand ago, with only 55K on the truck, was with Pennzoil Ultra 5-30 that I had left over from a previous Toyota. Thought I'd use it up as I had no other vehicle to put it in.
Here is the punch line: The growling has gone away! I noticed shortly after putting the PU in that it seemed to slightly diminish, but thought it was totally my imagination. Now with a couple thou on the PU, the growling is almost completely gone.
I'm happy, but puzzled as well. Thoughts anyone?
