Originally Posted By: Cujet
Tire balance gets worse with increasing speed. Suspension issues often cause vibration issues at certain speeds and not others. My Jaguar X-Type shakes at 70, but not at higher speeds. It's an AWD car, with worn out suspension. It's no surprise the thing shakes. But the tires are balanced and higher speeds result in a perfectly smooth ride.
Yeah I'm not sure, when I saw the back tires being balanced I clearly saw the rims had small dents on the inside not the face. Could even really small imperfections cause vibrations issues?
I clearly saw the inner lip of each rim move up and down ever so slightly.
I'm all for buying new wheels and tires if I have to. But I don't want to spend $1,700 if it won't fix the problem. OEM wheels will run me $250-275 each. Decent tires will be around $160 each.
