Hi all. Dumb harbor freight wheel bearing press question for everyone...
So based on the 10 million write ups floating around the internet I feel pretty comfortable with getting the hub and bearing out of the knuckle and getting the bearing back in. My question is when pressing in the hub do I use the same press plate I used to install the bearing as the back press plate? So when I am pressing the hub in, I am using the outer race of the bearing and not the back of knuckle as the back plate?
TIA!
TIA!
