Originally Posted By: djb
If the original tires are really worn that little, don't bother with shaving.
The difference in rotation rate will be less than simple geometry suggests. Tires with tread blocks move on their belts, and thus rotate on the effective belt diameter, not on the outside diameter of the rubber blocks.
As a thought experiment, imagine what happens when the tread block is several inches high. Estimate that the tire is inflated so that the contact patch is square -- as long as the tire is wide.
That's a really good analysis. I wonder if experiments have been done to prove the need to worry about equal diameter tires.
