Originally Posted By: Shannow
Like I've said previously, I'm not sure that these additives behave linearly, but my interpretation of the only data that I have is that
* 10% additiion of 6cst PAO will leave you largely where you currently are
* 10% addition of 6cst PAO will dilute your AW additives by about 9%
* If you are wanting to thin your 0W40 out to 0W30, you need around 50% 0W20, and then it's (probably) thicker than a shelf bought 0W30 (and with slightly poorer cold end performance).
Great analysis! I do remember reading something about PAO that it doesn't always play nice with additives and other basestocks unless you really know what you're doing, and of course I don't.
I like the caterham-style suggestions to mix a bunch of 0w-20 in of the same brand. I'm leaning toward just throwing a pint of MMO in there on December 1 (Australian summer, U.S. winter) and let it boil off slowly through March 1 when the overnight temperatures are better. MMO thins it, right? Widman calc used. What could I possibly screw up with MMO? Ring deposits maybe? MMO is really just pale oil and mineral spirits with very little additive. I might go nuts and throw in a half cup (1/8 quart) of M1 racing 0w-30 in with the MMO just because I can..... Mad scientist, I know. I need a white lab coat and test tubes.
