Is there any technique which allows you to flush your brakes by pumping the brakes, bleeding out the old nasty stuff from the bleeders, and just topping off the master cylinder with fresh fluid?
I thought you always turkey baster out the master cylinder and replace with fresh fluid before you begin bleeding procedure.
I know this to be true in my head and if so, I have to have it redone in my 2011 civic because all my mechanic did was top off the old fluid as he went without first removing the old fluid. The car has 27k miles and is 5 years old. (The old fluid was golden.)
Thanks for any help in advance.
