Originally Posted By: MolaKule
Quote:
Is this enough to form sufficient hydrochloric acid to do serious harm to an engine in the combustion chamber? Would the small amount of blowby gases laden with hydrochloric acid be enough to cause harm in the crankcase? Or are the acid neutralizers in a good motor oil enough to render this small amount harmless?
I don't think there are enough chlorine molecules to form an acid, and yes the calcium and other acid neutralizers would take care of what might be there.
The chlorine is used in the chemical process to cause reactions with the benzene to form the solvent.
As far as cutting fluids, a different chlorinated compound is used, and it is being phased out in lieu of Greener friction reducers and EP compounds.
Hopefully that finally puts it to rest! At least for now.
