Originally Posted By: Thermo1223
You do realize those fine iron particles do the micro polishing of the camshaft and rings?
Fine micro-polishing will occur naturally over greater miles. No need to polish the internal surfaces down too soon, the wear can simply occur later.
Pure conjecture on your part, do you have any evidence to collaborate those particles being harmful?
I think you meant to say "corroborate". OK, I'm assuming that hard iron particles, like carbon soot in the same size range, does wear internal surfaces more when present. Its obvious.
Magnetic plugs are at best a feel good move, drain the oil hot like you are supposed to and on time and everything will be in suspension.
Bunk. The more abrasive particles you get out of the oil, the better. Remember the oil filter doesn't catch everything under 30 microns.
The Scion had it's FF changed at 10k miles, I had thought I sent in the UOA out of curiosity but I did not yet. When it gets back I will post it.
Listen to OLM, it will not hurt the car but will save you money in the long run.
Lots of iron will be in that UOA, its happened every time. Since the engine is new, you won't notice it much. Why purposely wear your engine down though? OLMs are good, but not for FF oil, change that stuff out.
