Originally Posted By: The_Eric
Originally Posted By: DSparks
Technology is awesome
....it prob wasnt stock...i think the 707 hp is at the flywheel..prob bout 550rwhp or so in stock trim and real high 10's with a DOT street slick..impressive cars no matter
I don't think so. I read a report where they dyno'ed a stock Hellcat at 700 and change at the wheels, making the flywheel HP a bit over 800. This correlates to the figures that the OP posted up. If you plug in the 131mph trap speed and a curb weight of 4500 lbs, you get approximately 810 hp.
http://www.hotrod.com/cars/featured/1504-2015-dodge-challenger-hellcat-dyno-test/
Originally Posted By: hotrod
Strapped to the dyno, the eight-speed automatic-equipped '15 SRT Hellcat Challenger from Chrysler's West Coast media fleet produced a corrected rear-wheel peak of 620 hp, happening at the fuel-limited 6,200-rpm redline in Fourth gear. (Rear-wheel torque maxed at 579 lb-ft at 4,200 rpm.) By comparison, a stock '13 Chevy Camaro ZL1 six-speed automatic maxed out at 465 hp at 6,300 rpm (also run in Fourth gear and limited electronically by fuel), and 473 lb-ft of twist at 3,700 rpm. The completely stock '13 Ford Mustang Shelby GT 500 was a six-speed manual trans model, and in Fourth gear, put out peaks of 587 hp at 6,400 rpm and 575 lb-ft at 4,300 rpm.
Gahhhh! Now you have doubting myself...
I went back and plugged in the posted E.T. and approx curb weight in (instead of trap speed) and came up with numbers more in line with 700+ hp at the flywheel- I think it was around 750?
Anyway you slice it, they are impressive numbers for an otherwise factory car!
