Originally Posted By: jhellwig
Originally Posted By: crazyoildude
They still make the non e core a/c filters... They are nice filters i see them at advance and sometimes at auto zone here in NJ
The only non score pf48 and pf 63s are old stock. The have been replaced by scores.
Originally Posted By: GM4LIFE
Why not just run the bigger PF63? You can run the PF63 filter and it is preferred over the PF48. Walmart carries the PF63. Personally, I would run the Amsoil EAO17 oil filter or the Fram Ultra XG 10575 which is the PF63 equivalent.
Here is the GM bulletin stating that you can run the PF63 safely and that is has more filtering media:
Service Information Home Publications Number Search New Bulletins Bulletin Search Feedback Help
Document ID: 2597264
#PIP4889: Engine Break In Oil Filter Number PF48 From New Delivery - Not The Same As The Service Number PF63 In Owners Manual - (Mar 8, 2011)
Subject: Engine Break In Oil Filter number PF48 From New Delivery - Not The Same As The Service number PF63 In Owners Manual
Condition/Concern:
Some customers may comment that the oil filter # the engine came from the factory with is not the same # required for service per the owners manual and gm parts catalog. Engine was delivered with AC Delco PF48 and Service Oil Filter is AC Delco PF63
Recommendation/Instructions:
The PF63 filter has the same high quality attributes as the PF48 with but is 22mm longer which will provide an additional 22 mm of media filtration material. There will also be additional filtration protection during high mileage oil change intervals. The PF63 filter is a NEW release for the 2011 model year. These 2011 engines will be built with a break in oil filter of PF48 with service replacement being PF63.
The PF63 filter can be used on all M/Y vehicles if the PF48 is the service filter.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
That does not apply to his truck. It only applies to the 3.6l v6 in certain vehicles. And the factory filter is not a pf48 on those vehicles. It says on the filter to replace with a pf63 but it is the same size as a pf48 and does not have an adbv.
The PF63 was put onto these high feature GM 3.6 liter engines in the Traverse/Acadia/Enclage because they were having premature timing chain failures. The vehicles come from the factory with the short PF48 filter on them, but owners and servicers are advised to replace with the bigger PF63 with the hopes of greater protection. However, on my pickup I noticed a definite increase in lifter/valve noise on cold starts with the PF63 filter. This was not just something that I fathomed. When I switched back to PF48 that startup noise went away. I now happily use UPF48 (Mobil 1 filter clone). I cut open a PF48E and it seemed like a perfectly competent filter. However, I'm just more comfortable with the filter with metal internals from Mobil 1.
