IndyIan
Thread starter
Originally Posted By: ExMachina
Siping should only be done on newer tires, from what I was told. I used to have this done at Discount Tire (good tire chain), and they mentioned this, maybe because they weren't controlling the depth of cut, don't know.
Siping won't help noise much, but it helps break up wet films on top of ice and water on the road. Thats why you see winter tires with so many tiny sipes built in.
These days I just run the 40,000 mile high speed rated Michelin Xice3 tires already heavily siped, and that tire acts like an all-season tire too, remarkable really, long wearing.
I just ran a set of new old stock Xice's on the Tracker for the last 2 years as well. They worked pretty good, better wet traction than cheap 3 season tires, and are down to about 1/2 depth.
The CRV has a set of 9 year old Xice's down into the all season compound, so we should get a new winter set this fall too. It's tempting to just get a set of Xice3 and run them for the couple years we plan to have the CRV... They are an $800 set of tires up here though!
