Originally Posted By: doitmyself
Originally Posted By: 2civics
So in theory, if I don't clay and polish, I'm "locking in" contaminants and debris with the seal? Not lazy, just have some back issues.
You're sending mixed messages. In your first thread, you stated that you wanted the longest lasting, best protecting product. In this thread, you start out saying you don't want a product that requires a lot of preparation. Unless someone states otherwise, I don't think you can have both.
From this, what is seems you really want is an AIO (all in one) sealant that contains a small amount of cleaner. Duragloss 105 fits this bill, as well as others.
Most high end sealants have NO cleaners, thus necessitating a thorough pre cleaning. Note that the cleaning is also necessary for proper bonding, not just to avoid "sealing in bugs and debris".
Also, don't confuse cleaning the paint (removind contaminants) with correcting the paint (removing defects-swirls, haze, etc.).
Maybe you should be asking about AIO's instead of high end sealants??
Also of extreme importance is technique. Using wrong washing technique can induce swirls. Using the wrong applicators, towels, etc. can result in marring also.
Best of luck in your quest for the best.
No intent to send mixed messages. Just learning as I go here. If I have to wash with a degreaser and do a thorough clay bar before I put the sealant on, I am willing to do that to get the results of a top end sealant.
