Originally Posted By: t1snwrbrdr12
I have loose cv joints I believe. Trying to solve a vibration on acceleration. Pretty widespread problem and fix is the cv joints as per identifix and resources I've checked.
Make sure you don’t have worn engine/trans mounts that are causing the drive train to sit lower in the cradle than normal. Lowered cars also can have this sort of issue and need a plate installed under a mount to correct the inner CV joint angle.
