Ok, well a little background info. Ive got an 07 Silverado 5.3, about 70k miles, just bought it. It mostly sits with the occasional trip on the weekend or a short hop to the grocery store once a week. I mainly put on not much more than 5k miles per year. Ive had problems with the Active fuel managment on this as well. 1 lifter would stick when put into AFM mode, after allowed to sit it would re-lock back into place and run fine. I have since disabled AFM on the truck. It also might be burning a small amount of oil, due to blow by on the AFM cylinders. I suspect this is due to cheaper oil being ran and gumming up the oil ring on these pistons.
So with all that I have been running some MMO with a shorter OCI trying to clean things out as good as possible without disassembling the engine.
Im getting to where I want to make a decision on an oil to use long term. I will likely run a 6 month OCI, kind of lining up with the changing seasons.
With all that what would be your recommendations? I am leaning toward Pennzoil Gold Syn Blend but am unsure what to think.
