Well, picked it up last night and like it so far. Even the exterior is starting to grow in me. Only issues I've noticed so far is it has newer tires on the front of a different brand, and the rear ones are worn kinda choppy in the inside edge, indicating to me the toe might have been off at some point. I think the previous owner just replaced the two worst tires and that's why it has newer ones I the front. It drives nice and straight though, doesn't pull, and the fronts look like they have been on for a little bit, and aren't wearing funny, so I'm hoping the alignment is in spec. Rear tires do make some noise being worn the way they are, but still have at least half tread in the center, maybe more. Also, when it sits awhile, it has a rattle at start up for a split second. My first thought would normally be a faulty ADBV in the filter, but the 2.5s use a cartridge style filter. Maybe some short ocis are in order to make sure things are cleaned out good? Looking through the oil fill hole, all I see is a baffle, but its spotless.
