OVERKILL
$100 Site Donor 2021
Originally Posted By: chrisri
If you look into ACEA 12 oil sequences you will see that max camshaft scuffling wear is the same for A3/B4 and C3 oils.
But may not be the same for LL-01, MB229.5, Porsche A40....etc. Often there is an OEM approval that's required above and beyond the ACEA one.
When it comes to MB specifically, the wear limits for MB 229.5 spec (full SAPS) are exactly the same as for MB 229.51 spec (low/mid SAPS). Same goes for LL-01 vs LL-04.
However, then there is the whole notion of just meeting the spec vs. exceeding it. All these wear tests are just pass/fail, so we don't know if a given oil passed it with an A grade or just C-.
And then of course the other ever present question: does it really matter to an engine during its normal useful life?
Question for you:
I used the Lubrizol tool and looked at the "relative performance limits" for the various Mercedes and VW specs and noted, as you stated, that they are the same. My question is, is the test rig used to test these limits the same?
I'm also curious as to why the S62 was singled out as not being acceptable to use LL-04 in it (which, by definition, has lower Zinc/Phos) but basically all the others are
The easy answer is that the levels of those additives are relevant to that engines health, but I'm not sure that it is the real answer, or one that is complete enough.
Question for you:
