Is there any safe way to change my brake fluid, flush it completely and replace with DOT4? I want to improve the hydraulic system and raise the boiling point of the fluid, plus the car was manufactured 2 years ago and the fluid could stand a upgrade/replacement.
I wasn't sure what to buy to do it for cheap, maybe a new syringe to suck out all the old fluid in the master cylinder, then top it off with dot 4 Motul 600 RBF, then gravity bleed each wheel? Would this work?
http://www.amazon.com/Motion-Pro-08-0143...N5TSYXNV052VW62
Found this also.
Found this also.
