Originally Posted By: chrisri
Other than lead all metals are fine. Lead is a bit higher than I would like to see personally. Oil dropped in viscosity to a 30 grade in only 1.7k for whatever reason. I would look into injectors for possible leaks, and if you are planning to do more tracking, consider some of the heavier KV100 oils of 15 cSt.
Interesting.
The lab says no fuel and viscosity was a 40 so I've gotta ask whether you are even looking at the original post or just typing for the fun of it.
Op.
As overkill has said without trended data there is no real way to say that wear metals are high. You need data to compare and that data has to come from your engine.
And you cannot compare wear metals on 2 different oils and call one better than the other as far as wear metals are concerned. A uoa doesn't work like that. They don't accurately measure wear vs different lubricants and because you are tracking the vehicle you'll never get any real trends developed because nothing is consistent.
Personally I wouldn't even bother with the uoa. No real insight can be gleaned from them. A uoa is done to monitor the condition of the oil and monitor filtration as well as contamination. Your intervals are so short the uoa is pointless.
Interesting.
Op.
