So I've been running 10w30 in my car and on colder mornings I had a slight knocking noise that was in time with, but separate from a slight lifter tick, and would go away after about 30 seconds to a minute. It was intermittent and didn't do it evey morning.
I had a few people recommend running a thicker oil but I said no because it only happens when the engine is stone cold (left over night and in winter only) therefore when the oil is at its thickest. When the engine is warm or has been sitting for just a few hours, start ups are silent.
Anyway it continued so I thought hey why not just try a thicker oil as I have some 50 weights lying around. I went for Maxlife 20w50 which I thought would be fine since we rarely even reach freezing point here on the coast.
Well, the morning after the dull knocking noise was now a loud tapping noise and it didn't sound good! Still does it most mornings and even today after work!
Yet again once its warmed up it runs perfectly smooth and silent! Even with the 10w30 in traffic with the a/c on in the midsummer heat it would still be nice and quiet, no knocks or low oil pressure so I don't think it is a work main or rod bearing.
Only thing I can think of is a dying oil pump, being a big I6 with a long crank, the oil pump has to pump that oil a long way to those last bearings! I'm thinking it's not pumping as fast as it should be which is starving the last bearing(s) of oil on start up and the thicker oil made it harder still to pump it out (engine turns over much slower too with the thicker stuff)
What do you guys think?
Cheers
Cheers
