So we have a 1 month old or so old John Deere Gator 855D, and after it had sat for I believe around a week, key out of ignition, I tried starting it and while it did start, the starter was turning just barely enough to get it to start after a good 15 or so turns. I'm sure it took slightly longer to start just because it had been sitting for a week, no fuel circulation or anything, but for the battery to be turning it so slowly, something was definitely wrong electrically.
Anyone know what it could be? Don't bother saying "check the battery for current flow when it's off", because you and I both know it will have some kind of a draw. It had no problems after being run for a few minutes, started just fine the next time, so it's not a bad battery or charging system. The battery doesn't seem to be bad either, I can run the radio for a while with it off and still start it just fine.
