I have a 1995 Lexus SC300 5 speed with just over 205K on it. Runs fine, except for a clutch problem. Sometimes when pushing down the clutch pedal, the pedal does not return as expected. It says depressed very nearly all the way to the floor. I can still shift with it like this. The pedal does come up very slightly from the floor and the car can be driven. Press the clutch down all the way to the floor and I can change gears, but it's hard to get it into gear, I assume because the clutch is not fully disengaged. I can get the clutch to return to its normal position by taking my foot and pulling the pedal up, then it springs back to it's normal position and operates normally again.
Is this a sign of clutch cylinder issues or something else? A little assistance would be appreciated.
