Originally Posted By: CT8
The whole bolt and carrier are the high friction points !
The WHOLE carrier doesn't need oil on it. Only the 4 slides that run inside of your upper and the cam pin area. Nothing else on the CARRIER needs lubricated.
On the bolt, you lubricate the rear tail, the gas rings, the ejector pocket, and the lugs of the bolt.
And one drop of light CLP oil on the firing pin.
OP: Gear oil stinks and stains clothes. I would avoid for that reason alone.
Run a thicker viscosity lube on AR's such as Weaponshield, M Pro 7, Breakfree LP, etc.
