Only two days on the track, only 1700 miles. I don't seem to have good luck with M1. Castrol GTX is looking WAY better or are two track days all that hard on the tractor like eta engine?
EQUIP. MAKE/MODEL: BMW 2.7L (M20B27) 6-Cylinder
OIL TYPE & GRADE:Mobil 1 0W/40
OIL USE INTERVAL:1,703 Miles
Black Stone Says:
Even though this oil hasn't seen many miles, the use that it has seen was probably tough on internal parts. Track time probably explains why metals are a bit higher than last time, even after using a much shorter interval. At this point, we're not seeing anything so high that we're worried about a problem. The TBN was very strong at 8.7 - lots of active additive left (probably due to the short interval), but we do suggest changing this oil before metals accumulate and make the oil itself abrasive. The trace of fuel is harmless and the viscosity was fine for a 0W/40.
M1 0W40
MI/HR on Oil 1,703
MI/HR on Unit 144,251
Sample Date 6/28/2015
Make Up Oil 1 qt
ALUMINUM 5
CHROMIUM 1
IRON 16
COPPER 6
LEAD 12
TIN 2
MOLYBDENUM 89
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 4
BORON 144
SILICON 5
SODIUM 18
CALCIUM 2317
MAGNESIUM 408
PHOSPHORUS 856
ZINC 1106
BARIUM 0
SUS Viscosity @ 210°F 63.1
cSt Viscosity @ 100°C 11.08
Flashpoint in °F 375
Fuel % TR
Antifreeze % 0.0
Water % 0.0
Insolubles % 0.4
TBN 8.7
Black Stone Says:
M1 0W40
MI/HR on Oil 1,703
Make Up Oil 1 qt
ALUMINUM 5
CHROMIUM 1
IRON 16
COPPER 6
LEAD 12
TIN 2
MOLYBDENUM 89
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 4
BORON 144
SILICON 5
SODIUM 18
CALCIUM 2317
MAGNESIUM 408
PHOSPHORUS 856
ZINC 1106
BARIUM 0
Fuel % TR
Antifreeze % 0.0
Water % 0.0
Insolubles % 0.4
TBN 8.7
