I see nothing wrong with running ST oils.
I've run several UOAs with ST lubes and they have done every bit as well as the big brand names. In fact, I ran two back-to-back OCIs at 10k and 15k miles each, with dino ST lube, using "normal" filters, and the UOAs came back perfectly fine.
If you want to dis the ST lubes, then please provide a basis (other than simple opinions) which would support your position. VOAs show the ST lubes to be reasonably constructed, and UOAs show they perform just as well, even under extreme OCIs. So, what's wrong with ST lubes?
