Oil was changed at time of sample. Did about 600+ highway miles of towing right at the end of this sample. Probably 3-3,500lbs with a 12ft single axle.
Make/Model: GM 5.3L V-8
Vehicle: 2004 Chevy Tahoe
Code:
OIL Ams SS Ams SS Ams SS Ams OE Ams OE Ams SS
MILES IN USE 9,246 8,124 6,069 3,165 3,008 9,569
MILES ON UNIT 186,682 177,436 175,381 169,312 166,147 163,139
SAMPLE TAKEN 6/29/15 11/30/14 10/23/14 6/23/14 5/6/14 1/25/14
MAKE UP OIL 0 0 0 0 0 0
ALUMINUM 4 3 2 2 3 5
CHROMIUM 0 0 0 0 1 1
IRON 12 9 7 3 7 18
COPPER 10 12 10 6 12 14
LEAD 30 7 6 2 5 14
TIN 5 0 0 0 0 0
MOLYBDENUM 160 144 139 68 89 132
NICKEL 1 0 1 0 2 1
MANGANESE 0 0 0 0 0 1
SILVER 0 0 0 0 1 0
TITANIUM 0 0 0 0 0 0
POTASSIUM 4 0 0 0 1 2
BORON 61 45 53 105 147 49
SILICON 28 31 25 14 18 25
SODIUM 9 9 8 3 7 10
CALCIUM 3461 3247 3475 1944 2284 3195
MAGNESIUM 14 12 15 8 10 13
PHOSPHORUS 627 702 658 658 790 644
ZINC 800 801 767 747 875 690
BARIUM 0 0 0 0 0 0
SUS @ 210F 62.6 64.6 63.8 58.7 58.3 62.9
Visc @ 100C 10.94 11.51 11.29 9.86 9.73 11.04
Flashpoint 420 430 435 410 430 445
Fuel %
Antifreeze % 0.0 0.0 0.0 0.0 0.0 0.0
Water % 0.0 0.0 0.0 0.0 0.0 0.0
Insolubles % 0.2 0.4 0.3 0.1 0.2 0.6
TBN 3.3 3.1 3.4 2.4 2.4 2.8
Blackstone Inc Comments:
Did you happen to do some towing over the last 9,246 miles? We only ask because lead came up so much. We often find some excess bearing wear when the engine sees some hard use, but if that's not the case, then maybe we're seeing a temporary particle streak. That might explain why the other metals are still in good shape. A particle streak is when a tiny piece of dirt gouges out some of the lead babbitt, causing lead to read high. Once it passes, it drops down, so this may clear up on its own. The TBN was strong at 3.3, but use 9K miles again and check back.
Code:
IRON 12 9 7 3 7 18
LEAD 30 7 6 2 5 14
TIN 5 0 0 0 0 0
NICKEL 1 0 1 0 2 1
SILVER 0 0 0 0 1 0
SODIUM 9 9 8 3 7 10
BARIUM 0 0 0 0 0 0
Fuel %
